Carclean.com organization Logo Protect your camper or caravan in 30 minutes, without waxing? Yes! With Monello Acquafobia and the handy "Mitt on a Stick," you can do it too. Forget traditional waxing, make it easier for yourself, and save time!
9.5
12.000+ reviews
Protecting / Exterior / Wassen en drogen
Protect Your Camper or Caravan in 30 Minutes
For many campers, protecting the motorhome or caravan is a tedious, time-consuming task. Traditional waxing takes your patience, muscle power, and your entire afternoon – goodbye vacation vibes! That’s why we’re sharing a quicker method in this blog that’s just as effective as waxing, but without all the rubbing and muscle pain!
With the powerful sealant Monello Acquafobia and the handy "Mitt on a Stick," you can apply a durable, water-repellent layer to your motorhome or caravan in just half an hour. Forget traditional waxing, make it easier on yourself, and save time!
Prefer (also) watching a video 🤓 on this topic? Click below!
Why Waxing is a Thing of the Past
Although waxing provides a beautiful shine and protective layer, it also has its downsides. It requires a lot of preparation, you have to buff every corner thoroughly, and then polish again to remove excess wax residue. Even then, the result isn’t always even.
This new method, using a sealant, offers a simple and time-saving alternative that protects just as well, but without all the buffing and polishing. Your motorhome or caravan stays cleaner for longer and is also easier to maintain. Dirt and insects stick less easily, and it is better protected against UV radiation.
What is Monello Acquafobia?
Monello Acquafobia is a high-quality sealant specifically designed for long-lasting protection of vehicles such as motorhomes and caravans. This spray coating creates a strong, water-repellent layer that repels dirt, rain, and UV radiation.
The major advantage is that it can be applied to wet surfaces, reducing the amount of prep work. With this product, your vehicle gets a protective layer without the need for waxing, making it much easier and quicker to apply.
Volwassene, Mannelijk, Man, Persoon, Penseel
How Does Mitt on a Stick Work?
Mitt on a Stick is a microfiber mitt on an extendable pole. This handy tool helps you easily reach all areas of your motorhome or caravan.
It’s especially useful for reaching larger surfaces effortlessly, saving you from back pain and sore arms.
By using this tool in combination with Monello Acquafobia, you can efficiently apply an even layer, even on hard-to-reach areas.
Autofiber
Mitt on a Stick PRO
(5.0)
€99.00
In stock
Step-by-Step Guide for Quick Protection
  1. Preparation
    Ensure your motorhome or caravan is clean. A simple rinse to remove dirt and dust is sufficient. The great thing is that you don’t need to dry it, as Monello Acquafobia can be applied on a wet surface.
  2. Applying the Sealant
    This can be done in several ways. Spray Monello Acquafobia onto the Mitt on a Stick washmitt, or another (microfiber) washmitt or sponge. It’s also possible to spray it using the stream of your pressure washer or garden hose, or even spray it directly onto the surface.
    Use Mitt on a Stick to distribute the sealant evenly. Work in small sections, so don’t try to do the entire side at once—work bit by bit. It’s easier if you don’t have Mitt on a Stick. In that case, spray directly onto the panel. It’s important to spread the product immediately using the pressure washer or garden hose. It’s a very strong sealant, so once it’s dried, it could leave stains. Work in sections for an even result.
  3. Rinse and Dry
    Thoroughly rinse the motorhome or caravan with a pressure washer. Afterward, you’ll need to dry it, but this is much easier as it’s coated. Just make sure to rinse the washmitt after use or put it in the washing machine.
Benefits of This Quick Sealant Method
  • Faster and Easier: The entire process only takes half an hour.
  • No muscle power required: Unlike waxing, you don’t need to buff and polish, so you can easily treat the entire vehicle without any effort.
  • Durable Protection: Monello Acquafobia provides long-lasting protection against dirt and UV rays, keeping your motorhome or caravan cleaner for longer and reducing the risk of damage. The coating lasts for 6 to 12 weeks!
  • Convenience of Mitt on a Stick: With this handy tool, you can reach even the most difficult spots without climbing or straining your back.
  • Dries Easier: Once a vehicle is coated, it dries much easier.
Make It Easy for Yourself
For those who want to protect their camper or caravan quickly, effectively, and without hassle, this method with Monello Acquafobia and Mitt on a Stick is the perfect solution. It not only saves time and muscle power but also provides excellent, durable protection without all the work of traditional waxing.
We hope this blog has given you good tips for quickly and effectively protecting a camper or caravan. Get started with Mitt on a Stick and Acquafobia, and become a true CleanRider!
Lees de blog
Lees de blog
Exterior / Wassen en drogen / Protecting
Lees de blog
Beker
Washing and drying / Exterior / Wassen en drogen / Pads en doeken
No running water available but your car is dirty? No problem with GYEON EcoWash! Perfect for camping, living in an apartment, or any other reason you don't have access to a tap.
Autofiber
Mitt on a Stick PRO
(5.0)
€99.00
In stock
  1. Preparation
  3. Rinse and Dry
Lees de blog
Lees de blog
Lees de blog
Beker
