Carclean.com organization Logo CleanRiders' Vincenth is helemaal weg van Bead Maker van P&S Renny Doyle. Ontdek ook de magie en bescherm je auto in slechts 10 minuten! Wie wil dat nou niet?
9.5
12.000+ reviews
Bescherming
Protect your car in 10 minutes with the magic of Bead Maker
Protect your car in 10 minutes with Bead Maker from P&S Renny Doyle? Discover how to easily apply shine and protection without streaks, even on glass and plastic!
For anyone who wants to protect their car quickly and effortlessly, Bead Maker is a fantastic solution. In just 10 minutes, your car will get a beautiful shine, water-repellent properties, and protection that lasts up to three months. No white streaks, no hassle, just stunning results.
In this blog, we'll guide you step by step on how to use Bead Maker for your paint, glass, and even your plastic parts, ensuring your car looks its best.
Want to see the accompanying YouTube video? Click below!
Why Bead Maker?
What makes Bead Maker so special is that it does more than just clean. While a detailer spray often only has a cleaning function, Bead Maker also provides long-lasting protection and shine.
It works just as easily but offers many more benefits, such as protection that lasts up to three months, as long as you give it some time to dry.
How do you use Bead Maker? First, make sure your car is clean and dry. Then follow these steps:
Handschoen, Volwassene, Mannelijk, Man, Persoon
Bead Maker step by step:
  1. Shake well
    As with many car products, it's important to shake the bottle well before starting. This ensures that all ingredients are properly mixed.
  2. Spray on the cloth, not on the car
    Especially if you're working outside or if the car is in the sun.
  3. Apply to every surface
    Apply Bead Maker generously. Spread the product evenly with your cloth. The great thing about Bead Maker is that it's safe to use on every surface and won't leave stains. That means you can even use it on plastic or rubber parts without worries. Afterward, just wipe it down with the other (dry) side of your cloth.
  4. Wipe for the perfect finish
    Once you've applied the product, wipe the surface again with a clean, dry cloth that doesn't have any residue to polish it up. This gives your car a beautiful shine like never before.
  5. Patience is key
    The only thing left to do is let the product dry. For the best results, it's important to let the car sit for 2 to 8 hours without rain or dust. If you apply it when rain is expected within an hour, the product is still curing, and that process will be disrupted, preventing you from getting the full 3-month durability. If you can let it dry overnight, you'll ensure the best protection.
Also works on glass
Bead Maker works great on glass as well, without leaving streaks. In fact, it has a water-repellent effect on your windshield. This means you'll need to use your wipers less often, as the water slides off the glass naturally. A small downside: if you do turn on your wipers, you might see a slight haze. However, this happens with all glass sealers and is nothing to worry about.
Don't forget your wheels
Bead Maker is also perfect for wheels. After you've cleaned them thoroughly, you can treat them with Bead Maker to keep them cleaner for longer and protect them from dirt and brake dust. This way, your entire car will stay looking great. An added benefit is that if you happen to miss a spot while buffing, it's easy to fix. It doesn't harden like a coating, so just a little more of the same product is enough to remove it.
Interieurontwerp, Volwassene, Mannelijk, Man, Persoon
Want to try it?
Bead Maker is the solution for anyone who wants to protect their car quickly, easily, and effectively. In just a few steps, you can provide your paint, glass, and plastic parts with long-lasting protection and a brilliant shine. All you need is a little patience during the drying process, and after that, your car is protected for the next three months.
We hope this blog has clearly explained how you can benefit from Bead Maker, so you too can become a true CleanRider, just like Vincenth!
Bescherming
Why Bead Maker?
  1. Shake well
  5. Patience is key
Also works on glass
Want to try it?
