Superhandig je auto wassen met de Pistola Corta
Are you tired of cleaning your car with a bulky pressure washer and struggling with that awkward, oversized spray lance? Meet the Pistola Corta from Monello: a compact and convenient spray gun that allows you to effortlessly reach every nook and cranny of your car without hassle.
In this blog, you'll learn all about how the Pistola Corta can significantly improve your cleaning routine and why you'll never want to go back. Discover the handy accessories that offer even more possibilities.
Would you like to watch the YouTube video about the Pistola Corta? Click below.
Innovative features and accesories
The Pistola Corta is exactly what its name suggests: a short and handy spray gun that gives you more control. No more hassle with an overly long spray lance that limits your freedom of movement. Thanks to its compact and agile design, you can easily reach difficult spots like wheel arches and rims. What makes this spray gun even more convenient is that it comes with 4 easily interchangeable nozzles. With these nozzles, you can effortlessly adjust the power and width of the water jet. Whether you need a powerful jet to remove stubborn dirt or a gentle spray for rinsing, the Pistola Corta always provides the right setting.
The included nozzles vary in degrees, allowing you to perfectly tailor the water jet to your cleaning task. The lower the degree, the more powerful and concentrated the spray. And for those moments when you only need low pressure, there are two special nozzles that you can use easily without switching devices.
Sustainability
One of the latest features of the Pistola Corta is its ability to swivel, giving you even more flexibility while cleaning. Essentially, you pull it back, but always make sure to securely click the nozzle into place and double-check to ensure it stays firmly attached. Regularly applying a bit of petroleum jelly helps keep everything running smoothly.
Be careful not to get too close to your paintwork to avoid excessive pressure. For those who use a foam lance for a pressure washer (such as Ava or Kärcher), the Pistola Corta allows for a quick switch between a foam lance and regular spray mode, thanks to the Quick Release Connector. This means you don’t need to buy an entirely new foam lance—just a different connector will do. This saves you from constantly switching equipment, saving both time and effort.
If you find the Pistola Corta a bit too short, you can opt for the Monello Quick Release Extension Bar. This handy extension gives you a little extra reach for more comfortable operation, without the drawbacks of an overly long lance.
This extension also comes with a convenient storage system for your nozzles, so you can quickly swap them without losing your tools.
For those really hard-to-reach areas, such as the underside of your car, there’s the optional underbody lance expansion (for AVA). This allows you to easily spray under your car and ensure every part is thoroughly cleaned.
The Pistola Corta is made from high-quality materials; the exterior is crafted from premium-grade plastic that can withstand rough handling. More importantly, the interior is made of metal, making it exceptionally wear-resistant and incredibly durable!
The reason to go for the pistola corta!
Monello's Pistola Corta not only makes washing your car easier, but also more efficient and enjoyable. With its versatile nozzles and handy accessories, no spot is unreachable anymore. Whether you want to quickly switch between high and low pressure or thoroughly clean the underside of your car, the Pistola Corta provides a solution for every challenge.
We hope this blog has helped you get started so you can begin using the Pistola Corta as well. Then you'll become a true CleanRider!
If you have any questions or need advice, feel free to contact us via WhatsApp, phone, email or check out our socials.
